1 - 6 of 6 Posts
Happy new year in advance folks.....
Is there a software/app that I can install on the master PC to monitor the sites being visited on my network for both the wired PC and wi-fi user computers?
A keylogger sort of thing for the network. I have a linksys router
cheers
Some routers are able to do that for you, check your manual and see if it has that capability. Some can send you a e-mail with the info.
I'm just heading out I'll check in a few days or others can give you a hand.
The wireless router I purchased a few years ago came with a program called Network Magic. It just makes it easy to setup your network and has some helpfull features for monitoring sites visited. I think they have afree version as well.
Agreed. Check your routers manual
1 - 6 of 6 Posts
