Hi All - My last TV purchase was a Pioneer Elite 52" a couple of years ago and I love it, I need to add another TV (different room) and use it as a computer monitor as well as a tv. I would want split screen, pip etc. I am looking in the 52" -60" range. I have always believed in "you get what you pay for" and need some opinions on what unit is the top dog out there as far as performance, features and reliability. I probably need 57 to come out and set up all my sets as well.....been meaning to do that for quite a while.
If you want 52"-60" and use it as a PC monitor, good luck. A 24" LCD monitor typically would have 1920x1200 native resolution (WUXGA), and a high-end 27" would be 2560x1440 (WQHD).
You are talking about doubling the diagonal (from 27" to 54" would put it in your range), which means the number of pixels in each direction would need to be roughly 1.41 times (and more for the 60") to allow a similar level of detail. So you'd need a monitor with over 2000 vertical resolution, and over 3600 horizontal. Even the highest-end TVs are 1080x1024, way, way, way less than what you would need from a computer monitor.
You would have to sit back far enough from it to make that 50-60" look like a 20" and then set your PC's screen resolution to something relatively low (1080x1024 or something close to that).
Bottom line, if you want to get a high-end 24" or really-high-end 27" PC monitor and use that to watch TV, sometimes, it will look awesome. But if you want to get a 50-60" TV monitor and use it for your PC, sometimes, it'll look awesome for movies, and crap for computer use.
Thanks Hugh - I'll go have a look at one. Is it the Viera S2 or VT25 Series?
wprager - So, you are not loving my idea?
I have used my 52" Elite as a monitor (can't remember the resolution) and it looks pretty good - or - good enough for me anyways. Will this cause any problems with the set? Thanks
Hugh (or anyone, for that matter), what's the deal with Samsung LED TVs? My sister is in the market (not the high end, though) and she liked what she saw (mind you, this was at COSTCO and I warned her about what TVs look like in showrooms). I never though of Samsung much, but checking the prices they are at the same level as a Sony (same size, similar features, even though the Sony had internet connectivity built in).
All the lcd and plasma panels can be used for computer purposes. Send an HDMI out from the computer and display 1920x1080 resolution. No big deal.
I use a 46 inch LCD sony as my primary computer monitor and it works just fine. At 3 feet back, I don't see the pixel structure and since it is for computer use ... what do I care if I see the pixels.
Just that if you are intent on computer use, then a plasma might not be the best way to go given the image retention issues especially for computer stuff. A good LCD with back light LED dimming is likely a better way to go. LG lcd THX units have the best viewing angles of all the LCD units on the market at the moment.
MaxWedge, I was talking the VT series. Spent an hour with one and really was blown away both with 2D and 3D.
Don`t know what you are using this for but I consider this a unit for nice home theatre. Not sure I`d waste the money for use with a computer but that`s just one man`s opinion!
Half the use will be TV - Sports and Movies - The other half PC. During Nascar races I like to put the PC in PIP with the race so I can keep on eye on the live web leaderboard during commercials. I am doing this now with a Dell LCD monitor/HDTV. I also want to hook it up to my antenna (as I have with my other sets) for OTA....just to make Stampeder proud.
Anyway - I just want to buy this once, so I need to get the best I can get going in.
Will expand on exercise ... eventhough you know what I mean.
Image retention. Still present and bothersome. If ignored becomes burn in before you know it.
Watch 2 w/s films let's say in a row. 4 hours ... then before you turn off the tV ... find some programming that fills the screen ... and set the sleep timer for 15 to 20 min to remove the effect of the retention.
All done. Ditto if you use the computer a lot on it.
Most people will sit well farther back from their 54" TV than they would from a 27" computer monitor, so do not need the same pixel density. A 54" plasma displaying a 1920x1080 (1080p) computer image will look just fine.
I'd seriously consider waiting as glasses free 3d tv is being worked upon pretty feverishly by the major companies right now. Unless you want to be one of those poor souls who early adopts and has a couple grand of 3d glasses laying around with no content to watch it on in the near future.
MichaelTLV, in 12 years or so owning various plasma TVs, I've never had to do that. I use my plasma TVs as PC monitor as I write this post. (NEC 4:3, can't remember the model number; Pioneer PRO-FD1, PRO-1150, PRO-111)
Dave, that's good for you. But say that to a whole bunch of my clients that have burn in and tell them it doesn't happen and it is only their imagination. These are not just sets from 5 years ago, these are sets that are 12 to 18 months old ...
Count yourself as an informed soul ... and in the small minority.
Hi Michael, thanks for the info. What did these people do to create that kind of burn-in? Is it because I always calibrate my TV to D65 (a practice I've been religiously been doing annually to all of my display devices since the first year of ISF's existence)? Because other than that I never really take care of my TVs' contents (ie I use them for spreadsheets, writing article, slideshow, viewing letterboxed movies -- on my NEC 4:3 --, watching 4:3 etc)
in all cases ... 4:3 viewing ... black bars on the sides ... and dynamic/vivid modes
Cuz men don't read no stinking instruction manual and they never noticed it until I pointed it out ... and it was kinda too late at that point.
I'm on the more paranoid side of things ... so I do the exercise routine after prolonged sessions of w/s flicks. Add to that ... IR ... always has been more severe on Samsungs than Panasonics.
The worst of it here is that the TV would have been more robust to burn in had they varied the material more in that first 200 to 500 hr of use ... but nope ... 4:3 right away ... when it was most vulnerable to damage.
That explains it! Also during my NEC 4:3 plasma, most TV shows were in 4:3 and starting when I own PRO-FD1, I no longer watched TV, only DVD and HD cable.
(plus I brake-in any TV for at least 200 hours before I really use it anyway -- thanks to ISF class way back when)
Related Threads
1.7M posts
115K members
Since 2001
A forum community dedicated to Canadian TV, computing and home theatre owners and enthusiasts. Come join the discussion about home audio/video, displays, troubleshooting, styles, projects, DIY’s, product reviews, accessories, classifieds, and more!
