I'm having a real problem.
I have a Microsoft Bluetooth 6000 Keyboard. Worked fine for about a month. A couple of days ago it stopped working.
I've tried virtually everything. I've done the simple things such as removing the device and adding it back. When I add it back, Windows finds the device, I input the pairing code and Windows successfully adds the device. If you go into Bluetooth, Windows says the device is available and working properly.
Problem is I goto use the keyboard and it doesn't work.
I tried to connect the mini numeric pad that comes with the keyboard. I was able to successfully add it and register it but it doesn't work either.
I have tried restoring to previous points but Windows 7 is unable to restore to any of the eight previous restore points I have. Thanks MS for producing such a fine product!
I have also uninstalled and re-installed Windows Intellipoint Software.
Any suggestions?
Any suggestions?
