1141 - 1160 of 1191 Posts
I really wish channel 35 was CTV2 or something. Or that CBC could broadcast their documentary channel on one of their sub-channels. It would be nice to have a few more OTA options than we have.
I am looking to finally pull the plug on Shaw having slowly weened the kids off the family channel etc over the winter and now they're pretty much solely on Netflix and our Plex server. I have a 2 story home with an old antenna mounted in attic that allows me to grab CBC (6-1), CKY (7-1), CKND (9-1) and CityTV (13-1) clearly. I'm not sure if I'm supposed to see other channels or not (I'm ignoring the french CBC, the SD channel and Faith TV. Should I be getting more channels that this? I made a Stealth Hawk and it gets the same channels as the old antenna so I've left the coax connected to the big old array.
My plan is to use a HDHomeRun device with Plex DVR to record the TV's shows we watch and just run a coax to the TV for live TV (sports?).
Premium Member
I doubt it. KNRR is a lot weaker and signals with a NM of less than -15 dB are impossible to receive because they are buried in the Thermal Noise Floor. If you are able to receive signals with a NM of less than -15 dB, either the tvfool report is wrong, or they have been enhanced by Tropospheric Propagation.
Think the transmitter at KNRR (12) is only running about 200w. That was a while back though, was chatting with the engineer about their tower lights. Also there is a lot of interference from channel 13 that kills 12 farther north. A good yagi pointed south from Winnipeg "might" have enough side-lobe rejection to still pick up KNRR but won't likely be reliable.
Is CKY off the air? Picking up WDAZ on 8 and CHMI on 13 but no CKY on 7 VHF today!
Sent the Engineer an email, will update asap.
>Their engineering team is looking into it. Hope it is an easy, simple, and inexpensive fix...
Didn't hear back from the Engineer about what happened. Working fine now here too.
KVLY
Last night I received KVLY 11.1 (uhf44) in Winnipeg. The signal was solid for 30 minutes or so. Uhf panel antenna on my roof facing south. Exciting stuff!
Last few scans I am missing CBWF/D (UHF51/sub ch3) from Winnipeg. Is it off the air? It's CBC's French channel. No sub-channel on their other transmitter (ch 27)
Also likely transmitter issues due to weather (?) for CKY channel 7, back on this am but was intermittant last 36 hours. Suspect ice covering the antenna caused transmitter shutdown due to high SWR...
CKY was off the air for me Thursday evening prime-time and came back sometime after midnight. I checked my other channels on Thursday and they were fine, but CBWF was a little weak (7 out of 10 bars) I just checked it again and it's 10/10, but occasionally bounces down to 7 and back up to 10. CBC English (UHF 27) is solid at 10.
I didn't have any problems with CKY on Wednesday.
With the upcoming repack on the horizon, Winnipeg viewers should be e mailing KNRR to see if a channel switch from rf12 to another uhf channel would help the co channel interf. which prohibits canadian viewers picking up the signal.
@62 miles away it should be a no brainer for this station............
Even in their 316 kW analog days, KNRR’s Grade-A contour fell short of Winnipeg. Red River had replicated KCND-TV’s 1960-75 coverage right down to tower height and site, which had been based on overly optimistic expectations about Winnipeg indoor reception in 1960 and would never deliver it now.
Red River will probably maintain the status quo on KNRR until something changes. One thing might be the pressure U.S. broadcasters are putting on their government for Canadian cable companies to be subject to the same retransmission consent arrangements they make with U.S. systems. This is something they want included in the NAFTA negotiations. If KVRR/KNRR can undercut other Fox affiliates and finally (after more than 30 years) get the CRTC’s blessing for cable carriage in Canada, they could make a bit of money out of Winnipeg at last.
4.44 kW from 431 metres AGL, 10 kilometres or so west of Pembina: Enough to deliver a reliable signal to the Shaw head-end on the south side of Winnipeg? Or would they need to do something else— microwave, fibre optic, UHF frequency, power increase on RF 12?
Having ch 13 broadcasting so close to the city pretty much pushes FOX 12 out of the market. This was likely a strategic move by the CRTC and local broadcasters. If Shaw were allowed to carry KNRR I think they would be using high bandwidth carriage such as fiber unless the studio at Fargo decided to uplink to satellite, which I do not believe they are doing now. There are other FOX affiliates that uplink their signal though; likely for low budget smaller local cable companies etc. Someone would have to take on the cost of up linking fees and/or fiber data, the latter likely being the cheaper route.
Maybe KNRR/KVRR already streams real time 24/7? Their webpage indicates a live news stream so I suspect they do, but not likely available for public use.
Thanks for the insight!
Interestingly, there was a plan that might have used adjacent-channel interference from channel 13 to further marginalize KNRR in the Winnipeg market. When the channel 13 licence was up for grabs in 1985-86, CKND owner Canwest was actively backing the Manitoba Public Television bid, which proposed using low-power/low-tower specifications from either the University of Manitoba campus or somewhere near it. Even so, this would have meant that most Winnipeg homes using attic and rooftop aerials pointed south toward KNRR would have been receiving MPTV at maximum intensity as well.
The MPTV plan also would have kept the CBC-CKY-CKND local commercial TV triopoly intact, and would have been bad news to Prairie Public TV; though their involvement in the Winnipeg market was never as contentious as the Pembina and Portage stations' were.
CHMI-MTN's founding owners certainly had a financial interest in marginalizing KNRR, and intervened to the CRTC to keep it off Manitoba cable systems. But I think their interest in channel 13 was largely to get their hands on the last available VHF allotment in southern Manitoba at a time when VHF stations still had a competitive advantage over UHF stations.
KNRR Fox ch 12, wasn't working (receiving but no picture) for a few days. Rescanned and receiving fine now. Something must have changed in the data stream, maybe something to do with sub-channels, PIDs etc.
Reception close to Southern Border Question
I've recently moved close to the Canadian border on the US side -- Saint Vincent, MN (Across the Red River from Pembina). In researching what outdoor antenna I'll need to put up at this location, I was looking at what could realistically be expected to be received from Winnipeg. Initial analysis at TVFool, RabbitEars, etc suggests that only CKY is a realistic, reliable option - with the other Winnipeg stations not being an option (at least a reliable, realistic option).
I did find somebody over in the Fargo, ND thread over at AVS who lives just across the border in Emerson, MB who seemed to confirm this, although he admitted that his antennas point south and he receives CKY off the back of his antenna. He did state, however, that even when trying for Winnipeg he isn't able to get anything other than CKY.
Before writing off the rest of the stations, I thought I would ask here. I know that real-world results vs TVFool results can sometimes be different. For any of you in southern Manitoba near the border, does the above mimic your results as well? Only CKY being reliable? I guess I have no interest in going to extreme measures in pulling in stations that are only receivable during the evening hours, for example. So I was just going to look at VHF-only as that would cover CKY (7), WDAZ (8), and of course KNRR (12) and forget about the UHF Winnipeg channels based on reception maps. But for those of you near the border on the Canadian side - reliable OTA of Winnipeg starts and ends with CKY?
@easathor, I would try for channel 13 VHF, and of course 7 (CKY) since you have line-of-sight to their antenna and far enough from WDAZ (channel 8) to avoid interference. Signals from the UHF stations from Winnipeg are really strong but you are getting close to the horizon at St Vincent, but maybe a decent UHF antenna above tree height might just work. I am about 22mi north of you and I get all the Winnipeg UHF channels here with a home-made SBGH up around 40 feet or so. Just depends how badly you want to pick up the farther UHF stations.
Getting 13 from St Vincent might be tricky though with 12 being really close, but if you can get 12 in a null and some gain to the NNW you might just pick it up.
I am about 20mi north of you and pick up WDAZ and KNRR just fine on VHF, and KX4 quite often on UHF but not really reliably, but my UHF antenna favors the north. I have a VHF/UHF antenna I hope to install soon pointed south that might pick up KX4 and (NBC) from that tower reliably to complement WDAZ and KNRR.
There is one channel on a tower on the south side of Winnipeg that is really strong here, CIIT, on 35.1 UHF. If you can pick that one up with a mediocre gain UHF antenna you might just have some luck with the others with a good preamp, some height, and some antenna gain.
Good luck!
Anyone notice a drop in signal from channel 13 (City TV)? I have line-of-sight to transmitter, usually really strong here from my bi-directional grey-hoverman antenna or VHF yagi. Other channels are typical readings for signal/noise including other distant VHF/UHF signals from the US so I don't think it is band conditions, unless someone else on 13 has improved thair station and is interfereing...?
I had a problem with city tv on Sunday in Winnipeg. All the other channels were ok. I haven't watched it much recently.
City TV, coming in ok today but not very strong, just enough to play without breaking up... well almost just notice it is breaking up once in a while. They must have had to drop transmitter power or have other troubles at their site.
