1 - 2 of 2 Posts
Discussion Starter #1 (Edited)
Hello,
I recently updated my Desktop PC to Windows 7 (was running XP) because I like to torture myself.
I have a Macbook Pro that was able to pick up the desktop wirelessly so that I could stream files between the two.
However, since the Windows 7 update, I am unable to view either computer. I shared all drives etc. on the Windows 7 machine, yet the Macbook still won't pick it up.
Anyone else with the same problem or know what is blocking each other?
Thank you for any help thrown this way.
Did you turn off the firewall and enable sharing on the Windows 7 machine? These are enabled and disabled, respectively, by default.
1 - 2 of 2 Posts
