1 - 5 of 5 Posts
I have two older receivers. They are both connected to the same dish and stacked-LNBF via a splitter. Upstairs the program guide is working fine, but downstairs the guide says mostly "No Info". This was all working fine for over a year, until recently. Any ideas on what is the cause and fix?
Jake
When we first got our 2 530's, one never had the "no info" guide, but the other one often did. The only difference was that one was generally turned off at night while parked on an SD channel. The other was turned off while on an HD channel. We then made sure they were both always tuned to an SD channel before bedtime and never had a problem again.
1 - 5 of 5 Posts
