This is not really an original design, but just a build inspired by research and design by holl_ands, and a little borrowing from the Clearstream C5.
The 23" diameter loop is made of 1/4" copper tubing. The gap near the feed point is 3/4", while the attachment points are 1.5" apart, as this was the spacing on the plastic conduit clamp. The reflector is 2x1 fencing, 34" by 29", set back 13" from the loop. The bar of PVC up the middle is just for stability.
I tried a loop reflector, 5% bigger than the driven element, but the results were better with a continuous mesh, so I just went for it, resulting in something like the C5, albeit bigger. These loops are good performers in a smallish package for VHF-hi. For indoor builds, a cardboard box or styrofoam blocks of the right size and an aluminum foil reflector would probably do fine. For a lazy outdoor build, a milk crate might make a good frame. For this build, the cost of materials, including the balun was about $20. That PVC conduit at $0.99 for 10 feet has to be the best bargain in the hardware store! The fence was ~$2 per foot at 36" width. 10 feet of copper tubing is ~$7.
holl_ands' modeling predicts 6 to 7.5 dBi for a loop with loop reflector. The mesh seemed to do better, though I don't have a way to measure it. The C5 claims a peak gain of 8.4 dBi. In any case, I am finally able to pull in all 4 VHF-hi stations in my tricky location here in L.A. for the first time since June 12.
