1 - 4 of 4 Posts
i noticed that after the pvr as gone "stand by", after having finished playback of a recorded show, it will sometimes replay that show after a short while.
it does it in an odd, sorta buggy way though: audio first, and then the video kicks in about a minute into it. i dunno if this is intended behavior or some sort of "loophole" in the software, but it got me wondering: can you set a recording to loop indefinetely ?
as a side note, can you turn off that standby mode or set it longer, so that you can listen to the galaxy stations for more than a short amount of time, at a time ?
:eek:
That's really weird. It should actually go into a standby mode after a certain amount of time of inactivity including when a recording finishes
As for the screensaver "sleep" timer. There's no way to modify it. It's a hard 4 hours after inactivity.
1 - 4 of 4 Posts
