Hi all, the inexpensive but effective outdoor bedroom antenna I'd been using for years died on me (RCA ANT702Z Digital Amplified Indoor/Outdoor). I don't see it available anymore and it could've been a tad better, sometimes cutting out on a couple of my main channels, but overall pretty good.
I can't find an update to the Antenna Chart (Antenna Chart) so was just wondering if there is an update somewhere OR for advice on something comparable but maybe with just a little more strength to it. I think a 61 km/38-mile range should get me what I need.
All the techie stuff about antennas is way above my pay grade so I'm just looking for some simple advice for a solid, relatively low profile outdoor mounted antenna. I've noticed the compact RCA yagi's however, even those are a little bigger than I'd prefer but I'll go with one if that's the best option for me. I just tried one of those flat antennas you put in a window and it was kind of sad (not sure if you get what you pay for there and quality can vary? This replacement's a $20 Best Buy brand.) The original RCA I'm replacing was ~$20 so it would be nice if I could keep it on the moderately priced side, maybe no more than $35 but I could be convinced to go higher if the quality really stands out.
p.s., my house has white siding so a white one would be nice if it meets the above criteria.
Thanks!
Thanks!
