1 - 4 of 4 Posts
Just upgraded my PVR from 8300HD to 8642HD, I configured the Logitech Universal Remote 550 to control the new PVR. In the PVR menu, the first option is "Star". What is Star? Is there any way, in the universal remote, to remove this option?
Also, I cannot find the start-up channel in the Setting menu. I would like the PVR to start up with channel 518. Is this setting still available in 8642HD?
Star may be the * next to the 0 on the remote?
For the start up channel - press settings button twice and scroll to "viewer - power on" - select the desired channel.
There should have been no need to do anything to the Harmony since the codes for the 8300 and 8642 should be identical.
Discussion Starter · #4 ·
Thanks. I was looking for something that makes sense like "Start up channel"!!!
After I upggraded the PVR and configured the PVR into my Logitech remote, I found only a few commands not working. Mute, Prev (previous channel) did not work. Also, Volume Up/Down controled the PVR volume, not TV. I then setup the remote to learn from the stock Cisco remote and now all working.
BTW. Is there any way to dim the clock display of the 8642HD?
1 - 4 of 4 Posts
