Status
Not open for further replies.
1 - 3 of 3 Posts
I am trying to install a 9141 and am having some issues. I have run all new cables from the sattelite, installed the SW44, made sure it was plugged in and am not getting any signal and when i do check switch it is not recognizing the SW44. It is still saying I have the SW21. When I was hooking up the cables to the LNB's I think I might have accidentally put the LNB's on the wrong sides. Would that make a difference or would it just pick up the other sattelite as long as I hook them up properly inside at the switch? What else could I check?
The LNBF's are identical, even if the casings look different, so it does not matter which side they are on.
Ensure that both 91 lines are on Sat 1a & 1b and that both 82 lines are on Sat 2a & 2b.
After that, ensure that Port 1 Output has the Power Inserter, hopefully that will get you going.
1 - 3 of 3 Posts
Status
