1 - 3 of 3 Posts
Can anyone tell me what I can do to fix my dvd recorder which refuses to record anything from my satellite tv for later viewing. It displays a message "Copy protected, cannot record" whenever I try and record something. Surely there is some code that I can enter to disable this block on the recorder. That's what it was bought for after all. To record stuff. Someone please advise. Should I just take the thing back and get a different recorder. Thanks.
I record all the time from my Bell HD PVR to a DVD Recorder, albeit in SD, never had a problem at all.
How are you connected.?
· Super Moderator
1 - 3 of 3 Posts
