1 - 17 of 17 Posts
I did search the forums here for more details on my question, but there wasn't enough information to fully answer my questions.
I purchased a Samsung 55D6500 LED TV last week. I have taken it off of torch mode, but haven't done any calibration on it yet.I find the PQ of TV channels to be excellent. What my wife and I can't seem to get past is the "Soap Opera Effect" when watching movies. I know why this is occurring, the 24FPS for movies vs 60FPS for TV. I can't seem to find a way to minimize this issue.
I did some research and did find some suggestions to this.
1. Turn Game Mode on - I did this, but it only improved the PQ somewhat.
2. Turn off Auto Motion settings - this did not improve it at all.
I did my first test with Ironman 2 from Netflix. The S.O.E was extremely bad in this movie. The scene of him jumping out of the plane, near the start of the movie, was terrible.
I hooked up my PS3 and tried one of the Harry Potter blurays. Turning on the Game Mode settings, did improve the S.O.E. quite a bit, but it was still noticeable.
Has anyone here with LCD/LED TV's been able to get rid of this annoying problem? If I can't get this fixed by Saturday, I will probably exchange it for a plasma. However; I would prefer not to have to deal with the hassle of taking down my TV from the wall mount and packaging it back up. Any help would be greatly appreciated.
The "Auto Motion Plus" setting controls frame interpolation (soap opera effect). You say you've turned it off already, but it's input dependent - it has to be switched off individually on each input.
If you haven't already done so, switch it, and all the other picture "enhancements" off and change the picture to mode to "Movie". You should see a significant improvement and a much more natural looking picture.
If Auto Motion (which I presume is the frame rate multiplying circuitry) is turned off and you still have the effect then I would return it because PQ won't be getting any better.
Game Mode improves response rate but diminishes quality so I really wouldn't recommend turning it on during movies.
Discussion Starter #4
This is probably why the PQ of Netflix didn't improve when switching off Auto Motion. No way to turn this off for Netflix as it is an app from within the TV. Maybe I will try hooking my ATV2 and see if turning of Auto Motion for that input helps for Netflix.
I noticed the PQ was diminished quite a bit using this mode.
Thanks for all the suggestions. I will play around a little more tonight. Still curious if any LCD/LED owners have been able to git rid of this issue?
Discussion Starter #6
I'll check the Netflix app tonight. I was able to go into the Tools menu of the TV, which allowed me to change it to 3 or 4 different settings, like Standard, Natural, Movie, etc.. It wouldn't allow me to go into the advance settings though.
According to the manual, there appears to be settings for both LED Motion Plus as well as Auto Motion Plus. Is that correct, or just a typo? Turn both off, as well as Film Mode. If that still doesn't help, I can't think of anything else that would help. Any 120Hz TV that I've come across that has the S.O.E. has been cured of its ailment through adjusting those settings.
I don't know about this particular TV, but I played with a Samsung Blu-ray player last year, and most of the picture settings were not accessible if you played Netflix or another "app". For example, I couldn't set the aspect ratio of 4:3 movie that was always stretched. Pretty much any "smart TV" app behaved like this - wasn't complying with the settings for any input - so I wouldn't be surprised at all if they did the same corner cutting with newer and more expensive TV sets.
Even plasma has these issues. Some of the Panny's I've seen have terrible flicker with it's 48hz frame interpolation or the soap opera effect with it's 96hz interpolation if you use these. Best thing to do is turn all that crap off and put it in movie or cinema mode for a simple solution, or get someone to calibrate your set for you.
Discussion Starter #11
So I ended up exchanging my LED TV for a Samsung 59" Plasma 6500 series. I absolutely love this TV. PQ is excellent and we can no longer notice the Soap Opera Effect. I should have gone with my initial gut feeling and went straight to a plasma instead of the LED. This TV is in our main living room and I have yet to notice any reflection on the TV. Thank you to everyone that helped with my issue.
Nice set, but make sure to get it off vivid or standard and onto movie or cinema as even still, plasma will have image retention in these high contrast modes. And vary your viewing if you watch lots of letter box movies, play video games with static images or watch stuff with tickers or scores as these can cause image retention as well.
My Panasonic plasma is seven years old and I haven't seen any image retention yet. My viewing is 90% sports (score bars and tickers) and movies (blackbars). The tv is always in cinema mode.
Cinema mode being the exact reason why you haven't, and being a Panasonic who make great plasmas. I wish my friends would take this advice as I always hear them complain about IR on the plasma they just bought, then after I ask them if they have done any kind of picture set up, the answer is always no, "I like the way the picture is..." Barf!
Most people purchasing a new tv complain that cinema or movie mode is too dim and the colours aren't strong enough, but if you watch exclusively in cinema mode for two weeks, the majority would prefer the cinema picture and not go back to vivid or standard. The torch mode you see at most retailers is very offensive to my eyes.
I'm surprised you had so much trouble turning off the fast motion feature to get rid of the soap opera effect. Then again, this is the same industry that thought Scan Velocity Modulation on tube TVs was a good idea! :p
Totally agree. I just helped a buddy "tweak" his 46" set the other day as all he did was, as most non-techies due :), pull it out of the box and fire it up. I was over there watching a Blue Jays game and I tried to hold my tongue as long as I could, but I just couldn't stand it anymore. I made a simple comment of, "...don't those uniform colours and grass (well fake grass at the Skydome) look fake to you?" He looked like his puzzled pug for a second and then said, "Yeah, they do." I then suggested movie mode. He said it was to dim. I said turn the backlight up. So he did, he was happy, I was happy, and the world seemed right again :). The picture was still a bit too bright for my tastes, but at least the colours and shadow detail came ALIVE!!!
1 - 17 of 17 Posts
