1 - 1 of 1 Posts
Here is a quick hack I saw that uses a PC + Kinect + Openni + NITE + FAAST + a USB UIRT to send gesture signals to any device. You can now control your rogers box / satelite TV or normal OTA TV with gestures
You have a small appliance PC under the TV with a Kinect attached you can take the input gestures via the kinect and then use the IR blaster to send them to the TV / Cable Box / Apple TV / HTPC etc Very simple but clever idea
http://www.kinect-hacks.com/kinect-...recognition-data-over-infrared-using-usb-uirt
Very cool I will try and build one on the weekend (any ideas where you can get a USB UIRT in Canada)
1 - 1 of 1 Posts
