July 18th: DSR530 Code CC Fixes, Features & Bugs
153661 Views 1045 Replies 167 Participants Last post by  NO-CRTC
Check your target version tonight/tommorow.
As was posted here earlier and a C&P from another site that references a VP's response to a subscriber regarding the upcoming code:
The new feature set, if all passes, includes the following:
- Far improved operational stability for channel tuning (far few lock-ups during channel change -- in fact, so far we have seen none from that cause)
- Far improved timer performance for DVR recording, and for PPV recordings (again, so far no failures)
- Far improved performance for playback of DVR recordings (again, so far no failures)
- New sorting criteria for recordings
- A way to jump to identified times of recordings (i.e. 1 hour in)
For the majority of us that were on A8, this is great news as we'll finaly get the long sought after features that BC delivered to a selected few hundred.
For those of us on BC just waiting for the box to die after too many reboots, this should be a life saver.
Do check out all the new features in the beginning of the BC thread.
Enjoy the improved stability that CC brings.
Have faith that while not 100%, it's the closest the box has ever been and that new and exciting stuff is in the pipe.
From my experience in the past several weeks, what was quoted appears true for the most part.
Unfortunatly my source of information that gave me a closer view than most is no longer available.
Good luck and enjoy the efforts of many.
I'll still be around to help out as best I can.
481 - 500 of 1046 Posts
I don't disagree and can advise that at least the bug has been planted squarley at the feet of the developer capable of making it happen, after that is anyones guess.
While universal remotes abound, they still work with the current toggle on/off.
Where the real value is in macro task oriented remotes that need to reliably know that the box is either ON or OFF to work properly and other automation systems.
Nothing worse than having your TV turn ON to watch a show when you had been listening to the CD player and then having the STB turn OFF because the initial state was unexpectedly ON and we sent what should have been an ON code that in fact turned it off.
Great! Now, where is this developer, and can he/she be bribed with doughnuts? ;)
Re - Recorder Killer Bug
My 530 has been very solid with CC however I discovered a recorder kill bug over the weekend. I noticed the Victordc reported the same bug that I saw. Here are the specifics of my problem. I have a Mon-Fri timer set for Leno between 11:35 pm and 12:35 am. Last Thursday night I missed a prime time show (can't remember which one) but found it from a west coast feed starting at Midnight and running to 1:00. I just pressed record while I had it highlighted, got the record icon in the guide then went to bed. I had forgotten about the Leno timer however I did not get a timer conflict warning when I pushed the record button for the second show. The next night when I checked my recordings I was surprised to find that it had recorded 25 minutes of Leno, running from 11:35 to midnight. At midnight it stopped recording Leno, and started recording the second show,, however after 35 minutes or 12:35 it stopped recording the second show. It appears that it stopped at 12:35 because that was the time that the original Leno timer was set to stop. So I missed the last 25 minutes of the second show. In the DVR list both recording were shown and neither were shown as broken. Not thinking much more about this on Friday morning I went through the guide for the weekend and set it to record several programs as we were going camping for the weekend. Again record icons were put in the guide and I made sure there were no conflicts. When I returned home on Monday afternoon ready to watch some hockey I was surprised to discover that no recordings were made over the weekend. I tried making a recording on the spot and discovered that no recording function was happening. At this point I suspected that the timer conflict from Thursday night had killed the record function so I went and did a front panel reset, (my 4'th since July 19'th) and all is well again. So it appears it's a bug, however it's minor and now that I know about it I'll be more carefull with my timers and do a reset when I setup a timer conflict. Hope this helps.
See less See more
My 530 just died
Well, I have had a bad day and felt the need to vent here.
I have quite enjoyed my time with my dsr530, bugs and all, but the last week has been pretty nasty. Simply watching TV without pushing any buttons is locking up the system. After watching for a few minutes any attempt to do ANYTHING is met with the blue dot on the 530 signifying the remote is being pushed, but nothing else happens. I can still keep watching the channel or recording that is going but thats pretty much it.
Front panel resets are only successful 50% of the time and of course 20 minutes of watching requires another reboot.
Starchoice is sending me a replacement unit and charging me the $13 shipping fee. I can live with that, I just hope I get a unit that works better.
Does anyone actually have a unit that NEVER locks up?
DrDave
See less See more
My 530 died in much the same way. Have had the new one for two weeks and it has worked fine. Can't say that this will continue but so far so good.
DrDave
I'm on my third unit and I've yet to reset it. "Knocks on Wood" as I'm sure I just cursed myself. I've had it for 2 months now and when i received it it was brand new with the A0 code on it.
Solid as a rock here.
After replacing a brain dead CC box a few months ago, other than 1 reboot to fix it up after I had been royalling screwing with it, it's worked like a charm.
I use LOD trick modes occasionally.
I records LOTS of HD content and weatch them the 2nd night while new ones records.
No missed shows or crashes when doing JUMPS over commercials.
Other than a bit of smoothness and polish needed, I'm very happy finally.
I don't have to depend/lean on my cable PVR as a back up.
My confidence has been restored.
Very pleased (now) with my 530
I went through three units over the course of a year and eventually returned the last one for a refund from Starchoice in June. Four weeks ago I decided to give it another go with the CC code and so far I’m very pleased. I’ve worked the unit quite strenuously including lots of HD recordings, LOD modes, etc. and I haven’t yet had to reset it even once. The brand new unit came with version A0 and I did nothing with it until it loaded CC the next morning.
The refurbished units that I previously received came with version A4. One could speculate that somewhere between versions A0 and CC there is code that leaves the machine in a state that eventually causes problems, even once new code has been downloaded. This is just complete speculation of course but considering the following:
- Each new code version must be downloaded and presumably "installed" by the previous version. If the previous version doesn’t perform this task perfectly the new version may be corrupted.
- Once a new version is installed it doesn’t completely "erase" the machine and start from scratch. You keep your previous settings, recordings, and who knows what else. So there is a possibility that the previous code could leave things in an error state that the new code was never expected to deal with.
- Even a "factory reset" may not totally clear the machine and start from scratch. For example problems in the flash file system could linger if a factory reset doesn’t truly reset everything.
Anyway, it’s all just speculation but if you get a new unit I think it would certainly be prudent to use it as little as possible until you’ve got the latest code installed.
See less See more
Could be *C is getting the message. I just received a replacement unit last week and it came preloaded with CC.
No problems so far... <fingers crossed>
Only major bug I've had with CC is shows not recording when they should be.
I was watching tv the other night and noticed it wasnt recording a show I have a weekly timer for.
I switched to the channel it was suppose to be recording and it started recording and caught the last 45min.
Same thing happened earlier except i had to force a record with the remote once i was on the channel.
Was this a show that crossed over midnight? If so may be related to the bug I noted in previous message.
Actually if you had a midnight crossover conflict a day or two before this occured it is the same problem since this bug disables all future recordings.
If it's any consolation, I used my connections to deliver your bugs and the precise details directly to their QA manager and the senior developer for those modules. At least we can be assured they are aware of it and will make some attempts to remedy it in the next or following software release depending on where they are now in the cycle.
New System
I received my new unit 2 days ago and so far have had no problems. Thats a far cry from the lockups every 15 minutes with the last unit. I still wonder whether it was a software or hardware issue but hey... Im happy.
Just as an aside, I noticed that 300baud received a unit with the CC code already installed, so I was interested to see what mine would have. It actually arrived with the A0 code and updated to CC the first night. Makes me wonder if they have multiple warehouses with differently configured machines or if 300baud received a refurb.
DrDave
More Timer Conflict Bugs in CC Code
It seems strange that after several software releases that the programmers of the DSR530 cannot comprehend the differences between the times and the days of the week. Gee whiz, there are 7 days in a week, and each day is made up of 24 hours. Given that fact, explain to me why I'm getting a timer conflict here:
The 1:03 AM on the first entry is for Sunday, not Saturday. However the program seems to think the end time is based on the same day as the start time. Nuts! It's not rocket science, but it is very poor testing, and very unstructured programming going on here.
See less See more
Is anyone else experiencing a lot of timer conflicts tonight?
First, my 7:00 - 7:30 weekly timer completed.
Then, my 8:00 - 9:00 weekly timer froze up on the "conflict screen" because it said that it conflicted with the 7:00-7:30 weekly timer. Of course, I did not realize this until 8:30 and basically lost the program.
I rebooted the machine.
Then, when it was about to record, my 9:00-10:00 weekly timer said that it conflicted with the 8:00 - 9:00 weekly timer. My gawd!!! :mad:
I deleted all of my Monday weekly timers and reprogrammed them.
I had the exact same results again.
Am I the only one? :eek:
See less See more
Not alone
You're definitely not alone...I'm getting all kinds of reported timer conflicts. The timers it reports as conflicting neither overlap nor butt against each other...at least a half-hour gap between them...lost several shows...
BUT, last night it recorded Studio 60 but forgot to stop...recorded 10.5 hours until I turned it on in the morning and noticed it was recodring something...
Nope! You're not! My 7:00 p.m. to 7:32 p.m. timer now conflicts with my 8:00 p.m to 9:00 p.m. timer. Never had a problem with it before...here we go again!
Are some of you guys setting these timers manually? If so, check your AMs and PMs... they might be causing the conflicts.
If you take a look at the image I posted a few entries back, you'll see that there is no AM/PM problem. It's definitely more programming bugs. It makes no sense at all.
I generally add a couple of minutes onto the end of my shows so that they catch all of the show and not truncate prior to the real end of the show. This really frigs the machine up. It should not, but it does!
Hey Gary, nope it is definitely not an AM/PM problem. In fact, I have had these weekly timers set for ... well ... weeks! It just started tonight, everything was fine last night.
If it continues, I'll give *Choice a call tomorrow afternoon. It is too late now.
If anyone hears anything about why this is occurring, please post! Thanks.
