1 - 2 of 2 Posts
Hi,
I have started using a Channel Vision IR-5000 to control a Xbox 360. The Xbox is located inside a cabinet.
When pression a button on the remote, most of the time nothing happens. When looking at the repeater led, it does signal that it has received a signal, but the Xbox does not response. I do get it to work, but it often requires me having to aim away from the TV. Has someone ever encountered similiar issues ? Is my problem due to :
- The Xbox 360 IR ?
- IR interference from the LCD
Thanks for your help
1 - 2 of 2 Posts
