1 - 5 of 5 Posts
I have two scheduled series (The Colbert Report and The Daily Show) set to record on channel 609 (CTV Calgary, I think) and for first runs only (not re-runs).
This week, the box is not recording any of the new shows (they're back from a 2 weeks hiatus). However, if I switch my recording to include re-runs, then they get scheduled as expected. So it looks like the IPG is seeing them as re-runs while they are really not. Anybody else experiencing this?
I get them off CTV Toronto and I'm seeing this too. The original air dates are correct, but I don't see the guest information. If I set the PVR to record repeats as well as first-run that also solves the problem for me, or at least it records the shows.
Discussion Starter · #4 ·
Yep. I checked the original airing date and they're correct. Tonight's episode show 20100728, but will not record if I set it to "first runs only". It only get picked up if I choose "first runs and reruns".
1 - 5 of 5 Posts
