Re-scaling SBGH Antenna for 470Mhz to 602Mhz
Newbie question:
Interested in building Single Bay Gray-Hoverman for the following location at 30ft high.
Rabbitears
Tvfool
Not sure about putting it outdoors. Will try putting antenna in attic or by a window first to see how it works.
I have been trying to learn/use 4nec2 software to try and use
Nikiml's Antenna or
Jed's to design their antenna for 470Mhz to 602Mhz (channel 14-35) and Hi-Vhf 174Mhz to 216Mhz (channel 7-13). (It is not working well for me. Will need to practice more and watch more videos on its use)
Channels (from Philadelphia -- Roxborough (PA))
I'm interested in are:
Code:
Real Virt
2 2.1 ME-TV
6 6.1 ABC
9 35.1 PBS
13 12.1 PBS
17 17.1 PHL17
23 23.1 PBS
25 29.1 FOX
28 10.1 NBC
30 3.1 CBS
33 57.1 CW
34 61.1 ION
I know 2 and 6 are lo-Vhf but I am willing to tackle those 2 channels at another time.
• Can I use a scaling factor as indicated on Jed's page
I have had a number of requests for this antenna for use at other frequencies. If you want to adapt this design for use at a frequency other than 575 MHz, then simply scale the geometric measurements in the tables below by 575 MHz divided by the desired frequency. For example, to use the antenna at 525 MHz, multiply all the measurements by 575/525 = 1.095. In this case, a value such as 300mm in the table would become 329mm, or 12 and 15/16 inches. This scaling applies to all the numbers.
If yes,
can Nikiml's or Jed's design be scaled from their peak dBi frequency using the above process.
• I really liked Jed's narrow band (dubbed X-GH8), but its a bit too narrow for the UHF channel range that I want (17-34 RF).
Can the band be widened without losing too much of its peak gain (~18dBi). Another problem I had with Jed's X-GH8 is that it gets too tall for using indoor when I re-centered frequency to 550Mhz from 615Mhz.
• Is there any significant difference between using solid copper wire vs Aluminum elements for building the zig-zag part of the SBGH? If indoors resistance to weather should not be an issue. I know Aluminum is lighter/cheaper than copper and is better for outdoor use.
Thanks your your help in advance.
