1 - 11 of 11 Posts
Banned
I'm using my secondary (Telus) backup internet because my Shaw is down. Yesterday, my signal was weak so I installed an amplifier with the brand Nexxtech (Digital broadband amplifier) and attached a 4-way BGI splitter and now everything works except the internet. Solutions? Thanks in advance.
How do you know your signal was weak? You should call in for a service call, and if needed, the tech will install a better quality amplifier for free and balance the signal properly for the internet.
If the Amp is 1-way then it will not allow internet, phone or digital service to work properly. Sometimes the best thing to do is let Shaw come aout and determine if an Amp is needed and they will provide one free of charge. Often splitters can be reconfigured or something outside can be corrected to improve signals eliminating the need for an amp all together.
I don't like random strangers in my house.
If you have a problem with your TV, phone, internet, appliance, heating etc., some "random stranger" may be the only way to get it resolved. Also, please bear in mind that any changes you make to the cable, if not done properly, might also result in problems for others.
They are not random strangers. They are professional service people that represent a major service provider. OTOH, I wouldn't let a cable amplifier from The Source in my house. ;)
a one way amp will allow return feeds through it, it just won't boost them. At least the FREE one's that shaw would install do. And not wanting "random" strangers in your house has cost you a totally uneccessary expense since the random stranger installer would have had your internet working.
1 - 11 of 11 Posts
