I picked up my new 8642 PVR tonight. Should have a chance to set it up on Sunday. I do plan on upgrading the hard drive immediately, warranty or not because as we all know, 160GB is simply not even close to being enough space for HD recordings, and all I record is HD. Will report back soon.
Edit by 57. Please note that certain drives may not work (as we have found in several other internal/external HDD threads). If you experiment with "unproven" drives, be prepared for disappointment.
People considering this upgrade should familiarize themselves with the iHDD thread for the 8300 first and realize that there are differences with this new PVR. For example, this PVR uses SATA drives, not PATA.
SA8000/8300HD - Internal Hard Disk Upgrade Works (Cloning too) See Post 1. - Canadian TV, Computing and Home Theatre Forums
As more information becomes available/pertinent, I'll try to add it here
Edit by 57: Does the PVR not report % space properly? Many people have reported the % space doesn't seem correct (internal and/or external), especially if there is not a lot of space used - 8642 User thread. Record at least 10 hours of HD and then see the percentages.
