New Telus Installation Questions
Hi all,
First off, I just want to say thanks for all the information you guys provide here. I always appreciate being able to look up other's experiences to make mine easier.
I'm getting Telus basic IPTV and Optik 50 installed this Friday in my new house. I just moved in and had a good look at what is pre-existing in the house. Right now, there are cat 5e cables all running into the powercabinet, with a fiberoptic drop coming in.
I have a couple of questions, which I could probably get answered after a long discussion with technicians and even then it might not be the right answer.
1. Will the installation technician re-terminate the cat 5e connections at the box into RJ45s? Will they terminate the user-end on the walls to RJ45? Currently they are behind wall plates and are not terminated.
2. I read somewhere (can't find it now) that they will provide switches when you get an installation. Is this true, or should I go and purchase the necessary switches for my network.
3. Currently my TV setup in the living room has an RG6 with no cat5e in the correct location. Would the technician install a new box and run a cat5e for me, or is this something that I should do myself beforehand. I want to put a switch in the living room to feed my ps3, xbox, wii, and TV.
4. I've read that you could use the STB's out if it is connected on RG6, but that option seems like a workaround solution. Would it be feasible, or should I just run a new cat5e?
For anyone interested, I'm getting both the basic optik tv and optik 50 internet for 55/month on a 1 yr tv contract. One STB is provided.
Again, thanks for your help!
