Just checked and tightened some cables and everything is working as it should now.
Edit by 57 - Unnecessary Quote Removed.
Thanks again. I Followed the above instructions and now both receivers are working. However, I only have satellite 82 and high def channels on the shorter cable run receiver and 91 and SD channels only on the longer run HD receiver? Also appears that the longer cable run picking up 91 isn’t seeing the DPP 44 switch ? Any ideas? ThanksUsing the closest receiver, I would disconnect the receiver at the switch and perform a check switch with no connection. Then I would connect the receiver to the " to receiver" connection of the power inserter and then perform another check switch.
I haven’t tried switching the HD receivers since installing the DPP44 switch. The SD 4100 receiver is connected directly to the #3 port of the DPP LNB and picks up both 91 and 82. When the SD 4100 was connected to the DPP switch 44 it would not work? I am not sure whether the line amp I tried is DPP compatible? Does it matter which 2 of the 4 ports at the DPP LNB are used to bring satellite signal to the switch? Please see pictures of line amp and 4100. Thanks again!The issue with the shorter run is puzzling, especially since both satellites show up on the scan. The issues with the longer run could be due to cable loss. More troubleshooting is required. What happens when the receivers are switched? What are the results with a 4100 receiver? What are the results with the line amp, which must be DPP compatible to work properly, connected to the switch output going to the most distant receiver?
Is it possible to test the receivers with a known to be working dish installation elsewhere?
Ok Thanks! I actually tried the DPP 44 Switch installation with and without the line amp. It didn’t seem to help with either scenario. My last update with pics did not have the line amp installed. The DPP switch 44 did help getting the new receiver to pick up 91 with 100% signal strength on the long cable run. I just don’t understand why it can’t pick up 82 on the long run? Also not understanding why my other receiver with the DPP switch 44 now only locks on to 82 and not 91? Wondering if I just need to go back to using the DPP quad without using DPP 44 for the HD 6500 and SD 4100 and then mount another dish to eliminate the long cable run to the other new HD 6500? This is how it’s currently connected.On second thought, there may be an issue with the line amp. It needs to pass DC from the receiver unchanged. To do that it must be powered separately or use the receiver's power and pass it through. I couldn't find any information on that exact amp but there are similar amps made for DPP so it's unknown if it is fully compatible.
Thanks a lot for all your help and advice! I appreciate it and will let you know when I get it figured out. I’m thinking a new dish for the long cable run might be the way to go. Due to surrounding trees I might have to do a remote post mount. Is mounting to the base of a large cedar tree a bad idea? What’s the best conduit to run the RG6 back to the building with the receiver?I don't see any issues with the connections. If the 4100s work then it must be an issue with the new receivers. Someone on site will be better able to diagnose the issues and get it working. I'd still recommend a second dish if that is possible. 250' is about the limit for RG6 with typical satellite equipment. It's quite possible that the frequencies used for stacking with DPP is causing signal loss or other issues.
Thx for the response. A consultant came out before I arrived, and they cut down about 20 branches in the area they recommended without change. They're considering hardware changes at this point, and we bought a feeder in the meantime and swapped it out, also without change.Is there an obstacle, such as a tree, that is blocking line of sight to 82 but not 91? The symptoms seem to indicate that.
