then yes the switch will work but remember, you need two lines into the switch but you can use 2 lines out instead of 4
its official name is DPP44 Switch, to avoid confusion
Thanks! I did order a DPP44 switch today. Not 💯 sure on the 3ghz cable rating? However, The current 250 foot RG6 cable and Quad LNB work for the 4100 SD receiver without any issues?
I do have 1 splice. What is the best way to check for voltage drop?by the way, is the super long cable run, is it one continuous cable, is it a 3 ghz rated coax, any splices in it? is it terminated with snap and seal weather proof connectors? those also will be a factor about it working or not but as others have suspected, it might very well be a voltage drop due to the long distance.
One possibility is older receivers and switches did not need to have 3ghz cable runs because they did not need the extra bandwidth for band stacking. DPP packs more frequencies on the same wire thus they need 3ghz cables so its also could possibly be one factor. It could still work with older spec cables, but it means the cable is not tested at those frequencies so it may have lower signal or voltage drops perhaps?Thanks! I did order a DPP44 switch today. Not 💯 sure on the 3ghz cable rating? However, The current 250 foot RG6 cable and Quad LNB work for the 4100 SD receiver without any issues?
Good explanation! I know that the buried RG6 cable was installed in 2008. That being said, do you think that because the SD receiver works with such a good signal that I need to worry about checking connections any further?One possibility is older receivers and switches did not need to have 3ghz cable runs because they did not need the extra bandwidth for band stacking. DPP packs more frequencies on the same wire thus they need 3ghz cables so its also could possibly be one factor. It could still work with older spec cables, but it means the cable is not tested at those frequencies so it may have lower signal or voltage drops perhaps?
Great info Guys! I Appreciate it! The SD 4100 works great with the original Legacy LNB and the newly installed DPP Quad. When I received new HD receivers, I replaced the Legacy LNB first with a DPP Twin and then the DPP Quad in attempts to get the new HD receiver on the longer cable run working. As of now I am waiting for my DPP 44 switch to try with the DPP Quad….. In order to make the DPP 44 work, I will need to cut the RG6 from dish to receiver. Will adding this splice have any negative effects to the long RG6 run if the DPP switch doesn’t work and I need to splice it back together? Thanks again!The RG6 only needs to be rated for 2.4GHz. 3GHz won't hurt and it might help. Other things such as copper core and shield instead of copper coated steel and aluminum helps with longer runs as well.
1761 is right about the cable stacking. Legacy equipment uses frequencies from about 1GHz to 1.6GHz. DPP pushes the top end to about 2.2GHz which is why 2.4GHz or higher RG6 is used. I assume the DPP44 and 4100 receiver used stacking since I think the 4100 is DPP compatible. If legacy LNBs were previously used then that could explain the loss of 82 on the long run with the DPP LNB and new receivers.
Would Legacy LNB’s with a SW 44 and power inserter offer a better solution than a DPP Quad with DPP 44 switch for the long cable run?Barrel connectors are rated at about a 0.5 dB loss, which is usually insignificant, and the potential of a DC voltage drop if the connections become oxidized. They also need to be rated at 2.4GHz or higher.
Thanks again. DPP switch 44 arrived today. I’ll give it a try and post results. Is the function of the power inserter to boost voltage to LNB or simply power the DPP switch 44?Don't know because there are so many variables. Just be aware that DPP and legacy components such as LNBs and switches cannot be mixed. Most newer receivers should work with legacy or DPP but some, like the 9500, may require DPP for technical reasons. Unless there are reasons why it cannot be done, installing a dish at the other location might be the best solution.
So I installed the new DPP 44 switch with power inserter and must have done something incorrectly as I lost signal to the receiver that was originally working and the receiver on the long cable run is still not working. I followed the instructions and made good connections at switch and power inserter. I ran a check switch and had neither the 91 or 82. Only thing I question is whether it matters which ports I use at the DPP QUAD LNB. I am currently using ports 1 and 2 at DPP QUAD LNB. Please see picture of switch. Note, Switch is currently by passed and back to running directly from LNB to receivers.It does both.
OK. Trying that now. So the DPP 44 Switch doesn’t care which if the 4 ports the DPP LNB are used?Using the closest receiver, I would disconnect the receiver at the switch and perform a check switch with no connection. Then I would connect the receiver to the " to receiver" connection of the power inserter and then perform another check switch.
