Which switch do I need
I`m confused on which switch I need for my setup. I currently have a DP twin LNB. But I`m looking to hook up 3 or 4 receivers (3100, 4100, 6131). Now I know I could just switch to a quad LNB and run 4 seperate lines but I only have 2 lines from the dish. Which switch do I need to use and do I need a power inserter (and can that be inside the house or has to be at the dish?). Ultimately I would like to run the 2 lines from the dish to inside my house and then run a line to each receiver. And if it makes a difference the cable run from the dish to house is around 40 feet.
