1 - 7 of 7 Posts
I always wonder when you hit the info button and you get the description of the program, There isnt enough space to tell you everything and it ends in ...
Is there a way to read the rest and if not then why is it there at all?
Does the info come from another source that does show the full description?
If you're in the guide, press info and get the "programme description", it should show you the entire description, up to about 4-5 lines. Sometimes if it goes longer than that, then you won't get the entire thing and may see ends of words, or ...
I hate it when Rogers includes something like "Enjoy this free preview of the something channel until some future date" in the description. When they do this there is very little room left for the actual description that follows, so it almost always gets cut off.
Premium Member
The Info button...not enough inf
"Creation"
Recorded: Sun 12/26
12:45pm 2hr 0 min
Save: Until I Erase
Enjoy this free preview of Super Channel HD2 till January 4th.
You can order this channel in minutes using your remote when the free preview ends.
(HD) (5.1) (2009) Following Charles Darwin's struggl PG/TV-PG, Stereo, Surround.
1 - 7 of 7 Posts
