21 - 40 of 42 Posts
Discussion Starter #23
By using my Windows Home Server to store my songs and pointing iTunes to the WHS, I can now put the HTPC on a Power plan that will hibernate the PC.
BUT I still want to shut it down completely and restart so hopefully the UEFI will be updated with that functionality (doubtful but one can hope)
Decide what components you want and then go to a shop like NCIX or Canada Computers. I have had most of my recent computers built at Canada Computers. For my latest build a few weeks ago I went with NCIX as they had some components that I wanted that CC didn't have - NCIX has just opened stores in the GTA recently. I was very happy - their customer service was excellent at their Scarborough store.
Hugh, did you get the motherboard mentioned at the beginning of the thread? I'm interested in the Dolby Home Theater capabilities.
On my current HTPC, I just discovered that similar capabilities driven by DTS Connect only work when routing audio through the Realtek S/PDIF output. When I switched it to HDMI, the audio all went through the AMD HDMI Audio driver which brought everything back to the standard 2-channel PCM audio or pass-through AC3/DTS.
So the question is... on that new Sandy Bridge board are the Dolby Home Theater capabilities available when audio is connected via HDMI?
Discussion Starter #27
Whoops, thought I published what I got.
I ended up with the Asus P8 H67M Pro with B3 revision.
One of the reasons I went Sandy Bridge is that Dolby Digital, TrueHD (up to 7.1), DTS, DTS-HD MA (up to 7.1) can all be bitstreamed over HDMI.
One funny issued I've encountered that is detailed here
Just a heads up. Media Player Classic Home Cinema doesn't currently play well with Sandy Bridge. Enabling DXVA acceleration in MPC-HC will cause stuttering and image quality issues during playback. It's an issue with MPC-HC and not properly detecting SNB as far as I know. Intel has reached out to the developer for a fix.
I hadn't seen this before. It took me a long time to fix but found the fix on Codec Guide.
Anyone have any suggestions on a small form factor case to use with a Sandy Bridge with a mini-ITX board? The Antec ISK-100 is about the size I would like but the reviews on this case are not so good.
I am looking for something quite small - this Antec case is 7cm thick, 25cm high and about 22ch deep. A little thicker is fine but I don't want it too big. The only drive I plan on including is an SSD and I will use the integrated GPU.
For Mobo I was going to use a Zotac H67-ITX, Asus P8H67-i or Gigabyte GA-H67N-USB3
Discussion Starter #30
I got the Silverstone Grandia HTPC Case which is a recommended case on the link from pnear. Obviously this is not what Wayne is looking for but I quite like it since it's a black horizontal case that will look good in a HT rack.
The only case in that list that really is the size that I am looking for is the Morex T160. I don't know why we don't seem more really small cases since the capabilities of the integrated GPU on Sandy Bridge are really quite good and the processors don't need a gigantic heatsink.
Why do you need a case bigger than a couple of litres when you all you want inside it is a mini-ITX board with a Sandy Bridge i3 2100 with a small heatsink and an SSD? With a properly configured case you could have the fan blow right onto the heatsink - kind of like the Antec ISK-100 but it seems to have some other issues which are noted in the SPCR review of the case. And this would make a great HTPC playback client and Netflix/Hulu client.
Gigabyte is using a hybrid BIOS.
Hybrid EFI Technology combines the benefits of GIGABYTE's mature BIOS platform including stability and compatibility with 3rd party products with 3TB+ HDD support from EFI technology, allowing GIGABYTE to offer the best of both worlds through a quick and easy BIOS update using GIGABYTE's @BIOS utility that is freely available from the GIGABYTE website.
Main part is still good old BIOS.EFI is used mostly for 3TB+ HD handling.
http://www.gigabyte.com/products/product-page.aspx?pid=3698#ov
I started out that way, using an AsRock HT, small form factor, squeezed in 1x 64GB SSD (boot) + 1x 650GB hdd (OTA pvr storage).
Later I wasn't getting great transfer speeds from my NAS (Dlink-323), so I decide to consolidate the two, and got an i3 and m-atx case. I currently have 1x64GB (boot), 1x640GB (pvr), 2x1.5TB('nas' storage). Drives spin down when not in use.
So far, so good, and I already have a suitable system to inherit the i3 + MB in 6-12 months if/when i replace them with a low watt sandy bridge + MB.
Discussion Starter #35
So Hugh ... status update
Is it built and running?
Power comsumption?
Noise?
Does it do everything you need (and more)?
So far I am very disappointed.
The fan and case is very loud. I simply refuse to put it in my family room or home theatre. Second, getting Bluetooth to work has been a nightmare. I had the keyboard working then it stopped and now I am at a standstill.
I have had codec issues and so on.
Sad to say but so far this is very much a work in progress
Discussion Starter #37
I use remote HD and Wake. I don't see how an app can power up your pc? certainly it can wake it up from sleep mode.
Try chaning the case fans to a low rpm version. There are many 800/100o rpm fans that are virually silent.
I have tried blue tooth in the past and find that you always need to reconnect them. I and currently using the Logitech AirMouse and MS Arc keyboard ... great combo for me with the Logitech One remote.
I usually use VLC for playing any downloaded stuff. Has played everything I have thrown at it so far.
Discussion Starter #40
I am now using Wake, Remote HD, Boxee and VLC iOS apps for controlling much of the PC since my Bluetooth has been a failure. I also moved the HTPC into the room behind my projector so their is no noise.
I tried connecting the PC to my 4x2 matrix so it could service my family room and home theatre but it simply refused to work.
I've ended up buying a WDTVLive Hub for my family room and the HTPC is used for the Home Theatre. If I don't use it much, I might just convert the HTPC into a desktop for the kids.
Time will tell.
21 - 40 of 42 Posts
