1 - 3 of 3 Posts
I looked at all the stickies and could not find out how to do this. Can anyone please tell me if it is possible. Thanks
Using a firewire port on your PC may work - check on the firewire thread in the other Rogers forum, or doing the "Transfer to VCR" or whatever it is called where you hook up the outputs of the 8300HD to a tuner card on your PC. Note that this will give you a 480i picture, not HD and you will need a tuner card.
Thread moved to the HTPC forum.
Please elaborate on whether you wish to record HD or not, which type of connection you want to use, which computer you have and what capabilities it has, etc.
See the Digital Home FAQ (under help) "recording HD" and see the firewire thread under Rogers. Firewire just became active, so we're in infancy at this time.
1 - 3 of 3 Posts
