Repost:
If you're wondering if your dish does (or doesn't) have a clear shot to the satellites - here is a simple trick that you might like to try. This trick is applicable AFTER you have found the satellites and aligned the dish, but you're still concerned about trees, or maybe a roof overhang, partially blocking the view and reducing the signal strength.
It is like a final check. It can also be used if you think that the trees have grown taller since it was installed.
Make a small flat magnet-mirror:
Find (or cut-out*) a small flat mirror about 1-inch square. Find a flexible fridge magnet and cut out a square slightly larger than the mirror. Glue the mirror to the magnet (opposite from the fridge side) - crazy glue usually works. Don't use gobs of glue - you want the mirror parallel to the magnet's surface. Now you have a small flat magnet-mirror that you can stick to your dish.
(*Watch out the the sharp edges. Do not eat. Your mileage may vary. Sit up straight. Eat your vegetables.)
In use:
Now stick the magnet-mirror to the reflecting surface of your dish in various locations (very top edge, sides, middle, etc) and peek at the mirror from where the LNBFs are mounted. Just rest the side of your head against the LNBFs, each side, and close the other eye - usually close enough. If you need to be more accurate, then pull off the LNBFs for a few minutes and use your eyeballs where the feeds are normally installed.
If you see nothing but blue sky = good. If you see trees, or the underside of your roof = bad.
-end-
PS: DO NOT USE THIS TRICK WITH 2-way Internet systems (Xplornet, Wild Blue, others...) unless you totally unplug them. Three watts of 30GHz microwave (for example) up your eyeball might not be healthy. TV systems are receive only.
