After being turned off of the prices of stand alone CD/DVD duplicators I have decided to build my own and share how I did it.
I purchased a CD/DVD/Bluray duplicator control unit from the US.
It allows for attaching up to 7 optical target drives 1 source drive as well as 1 hard drive for storing disc images (I did not install a hard drive in my setup)
Next I picked up a tower that had enough room for 8 5.25 drives
I used a Zalman Z7 case as it had room for 9 if you take out the HDD caddy.
I am using a Corsair 450 watt PSU
I installed the source optical drive and the controller. I put the source optical drive at the top then the controller to separate the source & target drives.
I used 7x Samsung 22x CD/DVD drives.
