1 - 9 of 9 Posts
We're going to be away for 2 months and want to auto-record some TV shows to watch when we return.
How much does the PVR hold in terms of hours?
To answer that, would need to know WHICH PVR model you have. And then which size drive is in it.
The older units (8300), and the NB2s (8642) could have varying size of drives in them.
The NB3, only has a 1g drive.
I believe there is a sticker on the back/bottom, which says the size.
The 1gb drive on the NB3, is 'supposed to' be able to record of up to 240 hours of HD.
So depending on your drive size.. a 500g drive should be roughly max 120h, etc.
Discussion Starter #3
Ours is an older one -- 500gb. That should be enough for us to record some episodes while we're gone. Thank you so much! :)
Didn't think on this.. being ATLANTIC..
Different boxes than Ontario..
So not sure, if they have switched over to MPEG4 for the storage of recordings..
IF they are still on MPEG2.. then you MIGHT only get 60 hours..
But if you don't have a bunch on there right now (pretty empty) you should be fine, as long as you don't record like 10 shows a night :)
Discussion Starter #5
Thank you! There's only a few movies saved on there right now and we'll be recording only 3 one-hour shows per week for 8 weeks.
Worst case then is 19 mbps / 8b/B * 3600 s/h * 3 * 8 / 1000m/G = 200 GB
More typically 1 hour of 13 mbps MPEG2 requires about 5-6 GB/hour.
It would be very easy to test - record 10 hours of programming, make note of the % space used/left, then delete the 10 hours and subtract. I suspect you'll use roughly 1% per hour, perhaps a bit more. Utilize the channels you'll be recording when away for the testing since it can vary a bit by channel.
I’m new to Rogers myself.......just got installed yesterday. I left Bell over price reasons. I was wondering the same thing. Yesterday when they came over to install they gave me the most horrible bulky PVR box I’ve ever seen. My mom owned a PVR that displays the time on it made by Arris so I quickly swapped it out, its also a HD dual tuner, it’s nicer looking. She had it for a few years before she cut the cord. Hope I made a good decision in terms on space on the box. I also hope Rogers has better units then the one they wanted to give me yesterday lol now.
No, they don't have better ones in the Maritimes. Rogers equipment out here is archaic, as it's based on the old network Shaw had and not the one Rogers uses in Ontario.
Hopefully they'll update it to the Comcast X1 platform when they roll that out and it'll finally reach parity with Rogers in Ontario.
1 - 9 of 9 Posts
