1 - 10 of 10 Posts
The only real advantage would be to have a spare for troubleshooting or replacement in case of failure. If it's free or really cheap it might be worth it, otherwise, no. I believe ShawD covers dish and LNB repairs or has that changed?
Note: The 60e and 75e LNBs are not interchangeable.
Discussion Starter · #5 ·
my real concern is how long they last - i only have access to equipment every so often - read into that what you will. So, if they last 5 years, then it's time for a new one. If they last 10, then I'm good.
Like any piece of electronics, lifetime depends on lots of conditions. They could last 10 minutes or 10 years. If access is a real issue, get a spare. They don't need to be purchased from Shaw. You might want to check eBay or other sources of cheap parts.
I just re-used a 12 year old LNBF from an old round Star Choice Dish and mounted it on a 1m Dish to receive Galaxy 19, works like a charm, even though it has been sitting outdoors all this time with no power to it, must admit I was a little surprised that it still worked.......
1 - 10 of 10 Posts
