1 - 7 of 7 Posts
Hi does anyone know how to short jumpers jp1 and jp2 from the main box of the xl2 alarm system?
I want to get back default values and don't know how to .
The codes in there are from previous owner and he forgot the codes so I can't use it until I reset to default values.Thks
Discussion Starter · #6 ·
THks for reply but I have no power ,the keypads are not lit up nor do the sensors blink.So how can I tell if it is fried or to re-program it, because even if the board is at default values there should be some lights on somewhere? Any ideas? Thks
Discussion Starter · #7 ·
ok got power back but I'm new to this system, has anyone used this or has this , how do I program to arm system ,anyone willing to help a newbie step by step. Pls .There are 6 keys on the bottom of the keypad that are not marked what are they for?
Thks
1 - 7 of 7 Posts
