1 - 5 of 5 Posts
· Member #1
I have an external drive that I was using with Bell until it was made inoperable by Bell (a discussion for another thread).
Recently I decided to use it with my Apple TV after I installed ATV Flash. So I re-formatted the drive in Windows 7. It didn't work and then I realized, hey it needs to be formatted in FAT32, not NTFS.
So how do I format an external drive as FAT32 under Windows 7?
· Member #1
Discussion Starter · #2 ·
Hmm, seems no way in Windows 7 so after some googling I downloaded
FAT32Format from
http://www.ridgecrop.demon.co.uk/
extracted the file
fat32format.exe
from command prompt I went to the directory where I extracted the downloaded file then typed in
fatformat32 f: where f was my external drive
Job done in seconds.
· Premium Member
I usually use Partition Magic to convert to fat32. Nice to know there is actually a program that will do the same.
1 - 5 of 5 Posts
