1 - 7 of 7 Posts
walp: Good luck with getting -20db NM channels. You should be able to get everything in the green on your tvfool report. I do not think that any antenna will constantly get your channels in the -20db NM area.
Those are tropo stations, which means youll only get them inconsistantly during tropo conditions. The good news is that down south, you get tropo conditions frequently.
Go ahead and build the GH6n3 and point it 66 degrees magnetic. Your local stations are strong enough to get them off the backside.
Discussion Starter · #6 ·
Thanks, so I have confident to make one. Is it ok to follow exactly the dimension of the design or I need an optimized design? What if I just bend the zigzag at the same sections.
The safest best is to follow the exact dimensions of the design. Theres enough leeway in the design for 10ga vs 1/4" without much loss of gain to matter in your situation.
1 - 7 of 7 Posts
