1 - 6 of 6 Posts
Greetings,
First Post!!!!!
I moved my HD receiver downstairs and I can't get it to work for some reason. I ran the coax myself and I can confirm it working with a SD receiver but I can't get my DSR 505 working. I see when *C installed the cables when I moved into our new house, they have a small switch. Do I need to do the same to get HD working downstairs aswell??
I'm green at this so if someone could walk me through, that would be awesome. Personally, I think I'm missing a step to have HD in two different locations.
Thanks in advance
Vix02
Quad LNBF means you have a non-stacked dual system. You can run up to four tuners off that LNBF directly (a DVR is two tuners).
To run more than four tuners, requires an four input/eight or more output multiswitch, with all four dish lines rant to the multiswitch, and all your tuners ran off the multiswitch.
Greetings,
First Post!!!!!
Thanks in advance
Vix02
Folks,
You seem to be missing the issue. The OP said he just moved the 505 to a different floor in his house so first of all we must assume it was working correctly at the original location, and there is no need to check Dish / LNB configuration.
To me the clue is that "when *C installed the cables when I moved into our new house, they have a small switch". If he is truely using the Quad LNB / 65e dish there is no need for any "small" switch. I'd suggest he try eliminating the switch (using a barrel type F coupler - less than $1) wiring direct to the LNB, and see if that resolves his problem.
Anyway, that's my 2 Bits. :rolleyes:
1 - 6 of 6 Posts
