1 - 15 of 15 Posts
Banned
I have a wifi network that is b and g.... every peripheral I have is g (desktop, laptop, cellphone, etc).
If I wanted to get a new Xbox 360 it is only n.
I am looking for advice on what to do.
If I get an new n wifi home network then my cellphone, computer and laptop won't work. correct? is there a way to get around this?
Banned
that is great. I didnt realize they can be backward compatible.
if I pick up that router and if I use my old router (DLink DI 524) - can I run the two routers simultaneously in my house to boost the signal somehow for b and g? (while n will arise from the new router?)
I don't understand why are you getting a new router? Is your current network too slow?
You don't need a new router to use the Xbox 360. You only need a new router if you want the Xbox 360 to work at Wireless N speeds which may or may not be important to you.
an N router will run devices at both N and G (and most likely B)
A G router will run devices at G and B.
An N device on a G router will never achieve N speeds, and a G device on an N router will also never achieve N speeds.
Your devices will work at the lowest common denominator, i.e. G (limited by the router).
As Hugh said, you do not need a new router, unless you want to run the xbox at 300mbps vs 54mbps.
Also another thing to consider is your internet connection... if you only have a 5Mbps connection, and your wireless is 54Mbps... you are never even going to use the full potential of that wireless connection... N is really only going to make a difference between the devices inside your networking allowing them to connect to each other quicker, but you will still be bogged down by the slowest thing which is usually your internet connection.
Unless you have a 20Mbps+ connection, its probably not worth upgrading to N yet if you already have a router.
FYI: I used to use a g/b router and switched to an "n" router.
For my situation it was a gawdsend...as it made a huge difference in connectivety on different floors.
Not sure really whether it provided any speed boost...but the signal has been perfect everywhere since the upgrade...so you still may want to make a switch...if that is an issue.
Sorry...forgot to check back on this thread...
I use the D-Link DIR-655 Xtreme N Gigabit Router, (can be had for just under $100, if you look around)...and well worth the money...and it's fully backward compatible with "G and B" devices.
1 - 15 of 15 Posts
