1 - 9 of 9 Posts
I do have the Home Hub 3000.
Can not go into the settings
Every time I type 192.168.2.1 , it stays on the following screen, circle is turning, and never go further
11523
Already tried hard reset
Bell even changed the router for a new one
Was ok for a day, then it started again when the devices were connected.
Can it be a wifi connected device that create the problem since a factory reset make it work but the problem comes back once every device is hooked on the wifi.
Thanks for your help
Conflict in addresses? - one of your devices has the same address as the modem?
Have you tried a different browser? Bell only supports Chrome for some of it's services. It's also possible that an antivirus program or privacy plugin is blocking the connection.
Discussion Starter #4
Yep.. try with every browser available. Same ! Same thing on iPad, mobile phone, etc...
Do you any other routers or unusual network devices that would cause an address conflict or block network access?
Have you tried a hard-wired connection directly to the HH3000?
Have you customized the configuration of the HH3000 or are you running it the way that Bell sent it to you?
Discussion Starter #6
Dr. Drive.
No other routers ou unusual devices
Yes I tried hard-wired and it's the same...
If I factory reset, it will work. But as soon as a change the network default name ( BELLXXX ) by my own network name, All devices reconnect et can't access the router anymore. That's why I suspect a conflict with an actual device. I used the bell network app, and had been able to see all devices ip address.... No other 168.192.2.1 .... Still have no clue May be I will have to turn down every device, one by one and try to find the faulty one ! :-S
Have you tried accessing the router from a browser on the phone or tablet that works with the Bell network app?
I have Bell MTS and use http://home to access my HH3000. Does that work for you?
Thoughts:
  1. the app may not show a device with the possible conflict, so take notes from the "clean" unedited network SSID version
  2. Indeed - makes sense to try that, or reverse and bring one back on line at a time
Good luck.
1 - 9 of 9 Posts
