1 - 1 of 1 Posts
I've been searching for a (very) cheap High contrast grey screen for my new 16:10 Epson EX71 projector. I have found the 16:10 options limited to say the least, the best option I found was from B&H and would cost a fair bit to ship from the states. I'd really like the grey because this LCD projector is very bright but could use some help with the blacks, and some ambient light rejection would be nice for non movie viewing. Would going with a 16:9 screen be a bad Idea? I don't really plan on using a PC with this unit.
Also does anyone know if screen material will block IR signals? I put in remote controlled dimmers and they are limiting the size of my screen to about 92"... If I could still operate them "through" the screen I could go much bigger!
Thanks for any recommendations!
1 - 1 of 1 Posts
