1 - 2 of 2 Posts
I built this Yagi, and it works extremely well. I used 1/4” copper for the reflector and directors, and some 1/2” I had lying around for the dipole. VHF stations are stronger than I’ve ever seen, and it even gets the weaker UHF stations. It was a lot of work, but worth it. Hi-VHF 8-El FD-Yagi - OPTimized
Discussion Starter #2
How does everyone attach the elements? I tried aluminum cable clips, but they started to slide out. I then put some rubber tubing on the middle of them, and now they’re tight. They can easily be removed if I need to.
1 - 2 of 2 Posts
