1 - 20 of 26 Posts
Just curious what's out there.
Firmware version: SG48210424
Rescue version: 5566-softtest-v28b.34.98
In addition to the firmware version, I'm also curious to know if advanced DMZ is working for you.
Advanced DMZ not working for me
Rescue version: SG48210328
Looks like they fixed it on the next version? Is there any way to force a firmware update (or flash it myself)?
Firmware updates are pulled from the ACS servers over VLAN 33, normally on boot, may be able to try a power cycle, and if you are in a targeted range, it will pull, otherwise, you'll have to wait till your turn is up.
Discussion Starter #8
Just got pushed SG48221028. Can't check dmz. Update reset the router to default settings. So beware.
@habskilla - What was the common failure mode of A-DMZ... Was it not working at all before, or did it fail after some time? Would you say it's definitely fixed for you, or time will tell?
Hello. Mine is:
Firmware version:
SG4822102A
Rescue version:
SG48210424
User interface version:
5.0.6
Hardware version:
5566-000002-006
SFP ONT model number:
3FE46541AA
There is so many numbers here, I can't make hyde nor hair out of it. Does anyone know if mine's the latest?? If not, can you tell me where and how I can upgrade it? Thank you in advance.
Discussion Starter #19
Update happened during evening primetime. We were streaming something and then bam, no internet connection. At least this time I didn't lose any settings.
Firmware Update
I was just pushed firmware: SG48222050 with a rescue version of: SG48210424
Looks like Bell Aliant may finally be getting ready to release the Plume WiFi pods in Atlantic Canada!
1 - 20 of 26 Posts
