1 - 9 of 9 Posts
Is any one else having problems with HGTV? My in-laws called yesterday asking if I was having any problems with it as they haven't received it in over a week and sure enough I just got a screen full of static. They are on the Rogers HD VIP package and I am on the Digital VIP package so neither of us should have a problem and I would expect one of the digital messages if there was a problem.
You've posted this in a non-BDU specific forum so I'll answer for Bell TV. No issues receiving HGTV SD or HD. I suspect the problem may be with Rogers or with the local cable line. If it was more general this forum would have been flooded with reports befoe this. Good luck!
Discussion Starter #5
@reidw: You are correct, I should have posted this in the Rogers forum.
@57: Since you answered anyway and are pretty close by (my in-laws are in Pickering and I am in Whitby), could you let me know if SD works for you? I'm not sure if my in-laws thought to try the HD feed and I don't subscribe to the HD package so I could only test the SD feed.
@Tridus: That's what I'll probably have to do. I was just surprised when I couldn't find any mention of a local outage if it has been down for over a week.
Are they still using analog TV and is that channel now digital only? If so, they'll have to at least get the digital adapter. You don't often get static on a digital signal. ;-)
My SA8300HDs have Auto-HD, so when I tune to channel 46, I get the HD feed. I have one SD box, but it's connected to an audio receiver and not a TV. When I tuned it to channel 46 I got audio, so I guess it's working.
I think JamesK hit the nail on the head. HGTV is now digital only, recently removed from analogue. Static is not typical of tuning with a digital STB - usually it's either a black screen, or "not authorized". If you do have a digital STB, call Rogers to get it properly authorized.
Analogue Migration Thread: http://www.digitalhome.ca/forum/showthread.php?t=146605
Discussion Starter #8
Like I said, I was expecting a digital message but instead I got snow (digitally broadcast snow, why?...). We are both using our respective digital boxes and subscribe to digital service that includes the channel. It is most likely a problem on Rogers end in Durham/Oshawa and I will have to call them up.
Your problem has to be very localised or unique or I would have expected a flood of reports at DHC. HGTV is a very popular specialty channel. I'm wondering if it comes down to defective STBs although the odds of two boxes failing at the same time is a bit of a stretch.
(That's my last two bits on this subject. I'll leave this up to the people on Rogers from this point on. Hopefully nineball and his in-laws will find a solution. Good luck again!).
1 - 9 of 9 Posts
