Hey guys,
I'm having a problem with the subwoofer on my htib. I have an optical cable going from a macbook into the amp.
it's plugged into optical1 and I have the receiver set to DVD
ptical1, the sound is coming through but the subwoofer doesn't work. It's plugged in properly and turned on.
In the settings it is also turned on in all the places I looked. I have it set to stereo and also tried it on pliix and neo:6 and everything in between. I can't get the bass back on but I have noticed it says digital as well as lpcm.
I know the sub works becaus when I go through the speakers and turn on test tone, I can scroll through to my sub and it's functions fine.
Anyone know what's going on?
CF: Subwoofer won't work. Tried everything. Help.
