I have a third IPN330HD Telus STB that someone gave to me.
It has not been used for a while. Telus gave me a registration code so I should be all set.
However when I connect it, it tells me it is downloading some software and then, after a few minutes displays a powered by Minerva screen.
It also shows what looks like an error message of E0043 and seems stuck at a process 6/23 or 7/23.
All this is greek to me.
Any ideas on how to make it work or is it toast?
Everytime I try it does the same thing.
All advice gratefully received.
