1 - 6 of 6 Posts
This problem has been ongoing for awhile and we have tried everything we can think of to fix it. In the early morning and late evening we get the message that it is trying to acquire the signal and the light on the 530 turns red instead of green. Recordings still record and we can usually watch something on the DVR when this happens, but we cannot watch a live channel.
Sometimes the signal will come back and sometimes the only way to get it back is to unplug the receiver (which I know you shouldn't do on the 530 cause it might not come back on) Unplugging the signal cables sometimes works but not always.
We know the problem isn't the receiver because that was replaced about 6 weeks ago from the light cycling problem and the new one does it as well as the old one.
We figured it was a cable so switched all cables and it still happens. When we switch the two cables around the recordings don't always work. So there is definitely a problem with the cable or connections somewhere. Am now wondering if it could be the LNB. Any ideas anyone? And why would unplugging the receiver make it work again if it is a cable or even the LNB?
We are in an open area with no mountains or trees in the way.
Thanks for your help.
Could be the LNB. If your 530 is the only reciever you have, unplugging it also does a Multiswitch reset, disconnecting all power from your LNB. That could be what is fixing the issue sometimes. I'd personally go the route of a service call. But thats just me.
I had a similar problem with an intermittent signal. Mine was on the second antenna input (used for recording) which made it harder to diagnose. It would fail a few times a day.
It turned out to be an intermittent output on one of the LNB ports. Eventually it failed outright.
The fix was to move the antenna lead to one of the unused LNB ports. No problems thereafter, but now I have a 3 port LNB.
Move the antenna 1 lead to another LNB port and see if that clears it up. Good luck!
I had the same problem last week. Finally it was the LNB+ the antenna needed alignment.They replaced the LNB and realigned the dish everything is fine now.
Discussion Starter #6
Thanks everyone
GaryE. Signals are in 70's and 80's so that's not the problem. I guess I will call Starchoice this morning and ask for a service call. Sounds like it could be the LNB. Thanks for all your help.
1 - 6 of 6 Posts
