1 - 2 of 2 Posts
Alright, well my setup is a 51inch Toshiba RP with one hdmi slot. I have a few HDMI devices, so i purchased a 4 port hdmi switcher from monoprice. Hooked it up and got the handshakes out of the way and it has worked fine for 3 weeks now. All the sudden the sound comes on for one second literally and then goes away, but the picture is fine. At the same time sometimes i get the ybrpb output is blocked copy protection or whatever that is. I unplugged everything and put everything back and still the same? How can it work fine for weeks, and then decide not to work?
Anyone else have the problem?
Here's the FAQ on HDMI issues and things to check.
http://www.digitalhome.ca/forum/showthread.php?t=71112
1. Does it work properly when connected directly to the TV without the switch?
2. What length and gauge are your cables from the STB to the switch - from the switch to the TV?
3. What's the product ID number of the switch?
4. Do you have component video cables (or any other video cables) connected to the 4250 too?
5. Have you tried different ports on the switch?
1 - 2 of 2 Posts
