I always thought that there is no difference in quality with different hdmi cords. Its digital and either works or it don't. Does this stand true with longer hdmi cables?
Last week i hooked up my computer via hdmi in the living room with a 6 foot hdmi cable, the picture looked good and sharp. hd movies looked great. sd movies looked good.
So i bought a 5 meter (16.4 feet) cable, to run from the bedroom. i hooked it up and the the desktop did not look sharp and crisp as it did before. hd looked ok, but sd looked horrid, I also has some eye strain (could be unrelated though)
At 16.4 feet is there a difference in hdmi cables? our there other ones that size that would be better?????????
Should there be a difference in quality from 6 feet and 16 feet?????????
The cable looks a bit cheap kind of plastic (like the ones shaw give you). The other cable was a different material not sure what its called.
anyway here are the specs of the 16 feet cable
Rocelco
hdmi 1.3b full 1080p
Double shielded with gold plated connection
RoHS Stanard & HDMI certified
thanks for reading, thanks in advance for help
Rocelco
