Hi,
Is it possible that my HD signal is being compromised by the fact that the cable wire from pole to house is twisted around another wire?
At old house all worked fine with new (LG LCD HD 350 32") TV and DVR box from cable company (Eastlink in NS).
Then, moved house and the mysteries began.
•HDMI1 cable does not bring signal from cable box to TV. (Comes on for 5 seconds and then "no signal")
•Component cables do bring signal from cable box to TV - but with slight purple and green horizontal lines moving up the screen.
•Regular cable input also works fine.
•Cable technicians have replaced box 3 times and used many different HDMI1 cables and component wires.(they say it is my TV, but admit they are not sure).
•But, TV accepts HD signal perfectly from other source (BluRay) using either HDMI1 cable or component wires.
Hence, my thinking it may be exterior wire or exterior hookup. Especially after looking outside and seeing two wires entangled both near the pole and near the house. It is a very windy area!
Does anyone have advice.
Thank you for reading this.
