1 - 6 of 6 Posts
I bought the 9241 receiver and will be hooking it up this week , I plan on hooking up the dual lnb dish for this receiver do I need the sw 44 switch or can I just run the cables straight from the dish to the receiver, I have another dish that I run my other 2 receivers.
You can use an SW44 or 2 x SW21's, then 2 lines to the 9241, one to each input if you are going to use older Legacy equipment or a single DPP twin LNBF would allow you to just run 1 line to the rear of the receiver and then you use a DPP Separator.
No, you need to use a switch.
Doing it the way you think will result in 1 Tuner ONLY having 91 and the other Tuner ONLY having 82.
1 - 6 of 6 Posts
