HD and SD are they PCM or Dolby
217 views 11 replies 5 participants last post by  ShawViewer
#1 ·
Are all the HD channels in Dolby and the SD channels in PCM, I get some audio fluctuations with my new 9500 just wondering, noticeable when changing channels SD and HD
#2 ·
Most HD channels are DD5.1, although some are still DD2.0. Channels do not broadcast in PCM, so most/all SD channels are DD2.0, not PCM. Bell may change this, but it's probably a setting in the box if that's what you see at the AVR.
FAQ on the topic below. It probably needs some updating, but most of the information is correct.
#9 ·
When I had Bell satellite, almost all the SD channels were PCM stereo. The main exception was TMN (now Crave.) The HD channels were all DD. That may have changed but only because the SD channels became downgraded ATSC broadcasts instead of NTSC broadcasts. Specialty channels upgraded their audio for HD as well. That doesn't change the fact that most native SD broadcasts use PCM.
#10 ·
1. When I had Bell satellite, almost all the SD channels were PCM stereo.
2. That doesn't change the fact that most native SD broadcasts use PCM.
1. That may have been true when there were still analog channels. Rogers can pass the (audio) signal untouched through to my AVR via the box(es), regardless if they were legacy digital cable or now IPTV (Xfinity). All channels are, and were, DD after the switch to ATSC by broadcasters.
1b. What you had is irrelevant to the discussion today. You continue to muddy the waters regarding the topic of this thread. I believe if you saw PCM it was because that was what the Bell box output, not what was broadcast (with ATSC channels).
2. NTSC (analogue TV broadcasts) no longer exists, and by your own post you stated that ATSC is DD, therefore all channels are now DD2.0 or DD5.1 (and rarely some other DD format like DD1.0 or DD5.0 or DD6.1.)
The audio level fluctuations mentioned by the OP are probably due to the switch between DD5.1 and DD2.0, as discussed in my original response and in the FAQ I provided.
Please stop confusing readers of this thread by posting irrelevant and outdated information.
