1 - 2 of 2 Posts
Hey guys/gals, i am trying to find the sat 107 & 111 with my dish and tv right there by the dish. when i go to 4-3-1 in the options and try to tune the sat signal, i enter 4128 in the red box for EMM provider, and then the lower box is supposed to have signal strength right? ok. so then i wait about 20 seconds and the reciever just shuts down all rebooting on me and stuff! is this bad firmware? why cant i get any signal levels....:confused:
Hi Brimstone,
If you're running 00.10 or 00.13 software, don't use this menu to try and align the dish. As you've seen, the receiver will just repeatedly reboot.
You can access the same information (without the tone) in OPTIONS 4-7. Get the Ecb/no values as high as possible in that menu and you should be good to go.
This is no longer an issue with the latest 04.06 software.
1 - 2 of 2 Posts
